Wdym?
In theory why can’t I pull super from the new one and flash the old one?
That super has issues with apk install ADB and other issues
Why don’t you use 6.1.3 and switch the launcher to get round icon’s
Anyone want to feed this app to Claude Code (or any other AI tool) and see if it’s doing anything sneaky with root?
The fact that it demands root instead of using the regular device owner APIs is making me suspicious.
https://pizzabinblocker.com/
That’s what I did
I’m just asking in theory cuz you said i have to rebuild the rom
@ars18 modified services.jar doesnt work for it
Side point does anyone know maybe if the rom for the new build number has a better optimized battery life?
Ik thats true by the doovs
4 posts were split to a new topic: Kosher phones with Google Maps
does that mean this is the v2 that needs speaker fix?
Yes probably as far as my experience
@TripleU could you pm me please. Thanks.
@ChristopherMartin
https://forums.jtechforums.org/t/how-to-message-the-admins/4904
when i flash a magisk patched boot.img do i have to disable vbtema?
Usually
what are the commands to disable all the vbtema imgs
Wow I was actually just working on that
go to fastboot and run
fastboot --disable-verity --disable-verification flash vbmeta vbmeta.img
edit: run this in the directory with your vbmeta images
but that is not in nutron scots guide?
Ah I thought you meant when you make a patched boot image. When flashing you don’t need to disable verity
please explain, i do not understand, you patch the boot img through the magisk app then flash it on the device that the img was from (if you are not patching the boot.img od the device that the magisk app is installed on)
Don’t remember exactly how it’s done in the magisk app, I think there’s an option to disable verity in the patched boot image. Thought you were referring to that. Again, for flashing, you do not need to disable verity. At least on the TCL
What is the best open source messaging app?
