Anyone have any experience with RE of wireless keyboards? Protocol, etc…
Not buying a new dongle ![]()
2.4Ghz
2.4Ghz
my avatar is now static, dynamic is hard to keep track of…
enjoy the new look
if i put KEKA on KEE7 what will happen will it boot?
Probably but wont call
how do i flash the entire rom i do not have spflash tools (mac)
you can probably flash each partition seperately with mtkclient or fastboot, and erase the rest.
but ive never done this, no achrayus and i recommend waiting till more experienced guys answer.
also make sure to backup
What changed in the JTech privacy policy
I think it might be private
You are correct. It’s private!
no brom
Is it possible to get the 24six apk to work on a Kyocera? The one from apkdl wasn’t working
If it matters I can find out the model
I have it running on a Kyocera e4810 I downloaded one from apkpure
if on the magisk app there is no option to patch the boot.img of the device (it only lets you select one from storage) does that mean the device can not be rooted
i have version 65.0.5 running on mine
You are an air conditioner, not a freezer.
Similar, but not the same.
Air conditioners are more powerful then freezers
how to block an sdcard (slot)?
Fill it in with Glue, That is what Tag international said
there is away to block it on a software level
If the device is enrolled in an MDM (like TripleU MDM, the admin can disable external storage:
If the device is rooted, you can:
/storage/sdcard1But this requires root, and it’s not stable or recommended.
Credits: Copilot
