What device is that?
Edit: meant to reply to @anon73695882
on the qin f21 all you have to do is add an entry into the android manifest of the app you want to show up in settings. the settings app looks for the entries in apps and shows them in settings
Where can I get the SMS backup and restore that will work on a LG classic flip?
I just turned on my old phone that has texts from the past 3 years and want to have it exported so that I can import it on other phones
Welp time to book a new flight for double the price
My spirit points ![]()
Does memory integrity have to be off for so flash tool to work?
I had to turn off memory integrity with some MTK Drivers.
Yes usually
what are some good tcl home screen launchers, that work good on tcl’s?
is tcl flip 3 filter-able?
No, but there are verizon versions of the phone that don’t have a browser or KaiOS store
And please put all your questions in one message, don’t make tons of threads for nothing
@mods
I suppose these 3 new topics should be merged to TCL master thread.
@anon25202202 you can post all your small questions here instead of making a new thread for each one Random Questions That Don't Deserve Their Own Thread
anyone know what mouse the kyocera e4710 supports?
It runs Android 5.1 so try something that can work with that Android version
Does the GPS work properly on the TCL Flip Go? Because it literally doesn’t work for me.
Needs to pick up location once, then it usually works. First time can take a few minutes (it helps if you’re outdoors)
my friend was telling me about this website, where you put in a url, and it turns it into a apk. anyone know what it is?
