New tech unlocked. Codex CLI…
log
To get started, describe a task or try one of these commands:
/init - create an AGENTS.md file with instructions for Codex
/status - show current session configuration and token usage
/approvals - choose what Codex can do without approval
/model - choose what model and reasoning effort to use
▌refine my website colors. now i think it’s purple… make it blue glow on black
I’m going to scan the repo for CSS/theme files, find the current purple styles, and update them to a blue-on-black
glow.
You approved codex to run find . -type f | sed -e ‘s#^./##’ this time
You approved codex to run grep -RInE “8b5cf6|7c3aed|6366f1|99,102,241|6d66f6|7c6cf4|violet|purple|139, 92, 246|
139,92,246|#8b5cf6|#6366f1” – * | sed -n ‘1,200p’ this time
• Explored
└ Search rg --files -g ‘!node_modules/’
Search find . -type f
Read styles.css, cursor-trail.css, cards.css
Search 8b5cf6|7c3aed|6366f1|99,102,241|6d66f6|7c6cf4|violet|purple|139, 92, 246|139,92,246|#8b5cf6|#6366f1 in *
Read README.md, template.html, cursor-trail.js
• Updated Plan
Scan repo for theme colors
Identify purple/indigo references
□ Update CSS variables to blue/black
□ Replace explicit purple values
□ Add subtle blue glow effects
□ Review for consistency
Next, I’ll update the CSS variables and replace purple-specific styles with blue glow on black across css/styles.css
and css/cards.css.
• Proposed Change css\styles.css (+61 -58)
1 -:root {
2 - /* Dark theme color palette /
3 - --primary-color: #8b5cf6; / violet-500 /
4 - --primary-hover: #7c3aed; / violet-600 /
5 - --primary-gradient-start: #8b5cf6; / violet-500 /
6 - --primary-gradient-end: #6366f1; / indigo-500 /
1 +:root {
2 + / Dark theme color palette /
3 + --primary-color: #3b82f6; / blue-500 /
4 + --primary-hover: #2563eb; / blue-600 /
5 + --primary-gradient-start: #3b82f6; / blue-500 /
6 + --primary-gradient-end: #1d4ed8; / blue-700 /
7 --secondary-color: #64748b; / slate-500 /
18 --danger-gradient-end: #dc2626; / red-600 /
19 - --bg-color: #0f172a; / slate-900 /
20 - --card-bg: #1e293b; / slate-800 /
21 - --card-gradient-start: #1e293b; / slate-800 /
22 - --card-gradient-end: #0f172a; / slate-900 /
19 + --bg-color: #000000; / black /
20 + --card-bg: #0b1220; / deep midnight /
21 + --card-gradient-start: #0b1220; / deep midnight /
22 + --card-gradient-end: #000000; / black /
23 --text-primary: #f1f5f9; / slate-100 */
67
68 -.logo h1 {
69 - font-size: 1.75rem;
70 - font-weight: 700;
71 - color: var(–primary-color);
72 - margin-bottom: 0.25rem;
73 - background: linear-gradient(135deg, var(–primary-gradient-start), var(–primary-gradient-end));
74 - -webkit-background-clip: text;
75 - -webkit-text-fill-color: transparent;
76 - background-clip: text;
77 -}
68 +.logo h1 {
69 + font-size: 1.75rem;
70 + font-weight: 700;
71 + color: var(–primary-color);
72 + margin-bottom: 0.25rem;
73 + background: linear-gradient(135deg, var(–primary-gradient-start), var(–primary-gradient-end));
74 + -webkit-background-clip: text;
75 + -webkit-text-fill-color: transparent;
76 + background-clip: text;
77 + filter: drop-shadow(0 0 6px rgba(59, 130, 246, 0.5));
78 +}
79
166
166 -.card h2 {
167 - font-size: 1.5rem;
168 - margin-bottom: 1.5rem;
169 - color: var(–text-primary);
170 - background: linear-gradient(135deg, var(–primary-gradient-start), var(–primary-gradient-end));
171 - -webkit-background-clip: text;
172 - -webkit-text-fill-color: transparent;
173 - background-clip: text;
174 -}
167 +.card h2 {
168 + font-size: 1.5rem;
169 + margin-bottom: 1.5rem;
170 + color: var(–text-primary);
171 + background: linear-gradient(135deg, var(–primary-gradient-start), var(–primary-gradient-end));
172 + -webkit-background-clip: text;
173 + -webkit-text-fill-color: transparent;
174 + background-clip: text;
175 + filter: drop-shadow(0 0 6px rgba(59, 130, 246, 0.35));
176 +}
177
176 -.card h3 {
177 - font-size: 1.125rem;
178 - margin-bottom: 1rem;
179 - color: var(–text-primary);
180 - background: linear-gradient(135deg, var(–primary-gradient-start), var(–primary-gradient-end));
181 - -webkit-background-clip: text;
182 - -webkit-text-fill-color: transparent;
183 - background-clip: text;
184 -}
178 +.card h3 {
179 + font-size: 1.125rem;
180 + margin-bottom: 1rem;
181 + color: var(–text-primary);
182 + background: linear-gradient(135deg, var(–primary-gradient-start), var(–primary-gradient-end));
183 + -webkit-background-clip: text;
184 + -webkit-text-fill-color: transparent;
185 + background-clip: text;
186 + filter: drop-shadow(0 0 5px rgba(59, 130, 246, 0.25));
187 +}
188
278
276 -.btn-primary:hover {
277 - background: linear-gradient(135deg, var(–primary-hover), var(–primary-gradient-end));
278 - transform: translateY(-1px);
279 - box-shadow: var(–shadow-md);
280 -}
279 +.btn-primary:hover {
280 + background: linear-gradient(135deg, var(–primary-hover), var(–primary-gradient-end));
281 + transform: translateY(-1px);
282 + box-shadow: 0 0 12px rgba(59, 130, 246, 0.6), 0 0 24px rgba(59, 130, 246, 0.3);
283 +}
284
332
330 -#kitsSwiper .swiper-slide-active .app-item {
331 - transform: scale(1.2);
332 - box-shadow: 0 0 30px rgba(139, 92, 246, 0.7);
333 - filter: brightness(1.3);
334 - z-index: 1;
335 -}
333 +#kitsSwiper .swiper-slide-active .app-item {
334 + transform: scale(1.2);
335 + box-shadow: 0 0 30px rgba(59, 130, 246, 0.7);
336 + filter: brightness(1.3);
338 +}
339
504
502 -.upload-area:hover {
503 - border-color: var(–primary-color);
504 - background: linear-gradient(135deg, var(–primary-gradient-start), var(–primary-gradient-end));
505 - color: white;
506 -}
505 +.upload-area:hover {
506 + border-color: var(–primary-color);
507 + background: linear-gradient(135deg, var(–primary-gradient-start), var(–primary-gradient-end));
508 + color: white;
509 +}
510
508 -.upload-area.drag-over {
509 - border-color: var(–primary-color);
510 - background: linear-gradient(135deg, rgba(139, 92, 246, 0.2), rgba(99, 102, 241, 0.2));
511 -}
511 +.upload-area.drag-over {
512 + border-color: var(–primary-color);
513 + background: linear-gradient(135deg, rgba(59, 130, 246, 0.2), rgba(29, 78, 216, 0.2));
514 +}
515
• Change Approved css\styles.css (+61 -58)
• Proposed Change css\cards.css (+28 -28)
34
35 -.card-modern {
36 - background: linear-gradient(180deg, #141a28 0%, #0f172a 100%);
37 - color: #e5e7eb;
38 - border-radius: 16px;
39 - width: 100%;
40 - min-width: 240px;
41 - max-width: 260px;
35 +.card-modern {
36 + background: linear-gradient(180deg, #0a0f1a 0%, #000000 100%);
37 + color: #e5e7eb;
38 + border-radius: 16px;
39 + width: 100%;
40 + min-width: 240px;
41 + max-width: 260px;
42 min-height: 300px; /* slightly shorter to avoid clipping */
55
56 -.swiper-slide-active .card-modern {
57 - transform: scale(1.03);
58 - box-shadow: 0 16px 36px rgba(99,102,241,0.32);
59 -}
56 +.swiper-slide-active .card-modern {
57 + transform: scale(1.03);
58 + box-shadow: 0 16px 36px rgba(59,130,246,0.38);
59 +}
60
101
102 -.install-btn {
103 - display: block;
104 - width: 100%;
105 - margin-top: 16px;
106 - padding: 0.5rem 0;
107 - font-weight: 600;
108 - font-size: 0.8rem;
109 - font-family: ‘Inter’, sans-serif;
110 - line-height: 1;
111 - cursor: pointer;
113 - border: none;
114 - border-radius: 9999px;
118 -}
102 +.install-btn {
103 + display: block;
104 + width: 100%;
105 + margin-top: 16px;
106 + padding: 0.5rem 0;
107 + font-weight: 600;
108 + font-size: 0.8rem;
110 + line-height: 1;
111 + cursor: pointer;
112 + white-space: nowrap;
113 + border: none;
114 + border-radius: 9999px;
115 + background: linear-gradient(90deg,#3b82f6,#2563eb);
116 + color: #fff;
117 + text-decoration: none;
118 +}
119
#6366f1" – * | sed -n ‘1,200p’ this time
• Explored
└ Search 8b5cf6|7c3aed|6366f1|99,102,241|6d66f6|7c6cf4|139, 92, 246|139,92,246|#8b5cf6|#6366f1 in *
• Proposed Change js\ui\cursor-trail.js (+1 -1)
3 const rootStyles = getComputedStyle(document.documentElement);
4 - this.color = rootStyles.getPropertyValue(‘–primary-color’).trim() || ‘#8b5cf6’;
4 + this.color = rootStyles.getPropertyValue(‘–primary-color’).trim() || ‘#3b82f6’;
5 const { r, g, b } = this.hexToRgb(this.color);
• Change Approved js\ui\cursor-trail.js (+1 -1)
• Updated Plan
You approved codex to run grep -RInEi “purple|violet|indigo|#7c3aed|#8b5cf6|#6366f1|#6d66f6|#7c6cf4” – * | sed -n
‘1,200p’ this time
• Explored
└ Read console.html
Search purple|violet|indigo|#7c3aed|#8b5cf6|#6366f1|#6d66f6|#7c6cf4 in *
• Updated Plan
What I Changed
- Theme Vars: Switched to blue on black in css/styles.css (:root):
- –primary-color: #3b82f6, --primary-hover: #2563eb
- –primary-gradient-start: #3b82f6, --primary-gradient-end: #1d4ed8
- –bg-color: #000000, --card-gradient-start: #0b1220, --card-gradient-end: #000000
- Blue Glow: Added subtle blue glow effects:
- logo h1, .card h2, .card h3 use filter: drop-shadow(…) in css/styles.css
- .btn-primary:hover now emits a blue glow shadow
- Cards/Buttons: Replaced purple gradients/shadows in css/cards.css:
- .card-modern background is deep black gradient
- Active card shadow uses blue glow
- .install-btn gradient is blue (#3b82f6 → #2563eb)
- Swiper Glow: Active slide glow updated to blue in css/styles.css
- Drag-Over Hint: Upload-area drag gradient now blue in css/styles.css
- Cursor Trail: Default fallback color updated to blue in js/ui/cursor-trail.js
Files Touched
- css/styles.css
- css/cards.css
- js/ui/cursor-trail.js
How To Preview
- Run npm install then npm run dev, open the site and confirm the blue glow on black look across headers, buttons, app
cards, and cursor trail.
Tweaks?
- Want a brighter neon glow (e.g., cyan #00d1ff) or a softer near‑black background instead of pure black? I can adjust
the variables quickly.
▌ Write tests for @filename
⏎ send Ctrl+J newline Ctrl+T transcript Ctrl+C quit 30448 tokens used 93% context left
