I see some phones on the dumbphone finder that says phones like LG Classic, TCL Flip 4 and Sonim 5G can be used with verizon and AT&T, is this a mistake or has it been tested?
Anyone have an apk of 24six?
Here u go guys latest version should work on new flip phones
I thought you Linux users love it!
I can’t decide whether I should take the bait or not :rofl:
PSA
New play store updates block apps installed or updated from Aurora. Dunno about other sources, but depending on the app, I assume yes.
How do I know this? I uninstalled play store updates and the “update from play store to use the app” went away and the app opened as normal.
This does not concern you at all if play store is disabled on your phone.
Ouch
Yep. This is the screen you’d get.
With play store disabled or play store updates uninstalled, it goes back to normal and the app will open.
epic website…
That is advanced!
Just waiting for the day when they will finally pass fig looks like they are almost there and that’s why fig got scared and updated their phones
Do you think it’s because of our Troll?
ah so thats why its so expensive….
Because they had to pay so much for their web Developer
I wonder if this is similar to how they are going to enforce sideloading blockage.
is it interesting that i should post here some of the random python pjojects i made? (some have nothing to do with anything android etc. e.g. a snake game. also, they’re not apps. they’re just python scripts you can run in IDE or terminal with python installed)
Yes please :slight_smile:
Make a new topic
k. was always hesitant. I just made 1. I’ll have to polish up some of my other ones and post them
heres what i made so far:
it’s basically my first time almost posting so any criticism of how to write better would be highly appreciated.
Welcome @miki151
Dumbdroid dev!
Really happy to have you here :slight_smile:
I’m looking for an up to date waze APK or a converter that will convert xapk files properly to apk. I tried downloading the xapk from this website and using this converter to convert it to an apk, when I tried to install it though, I got this error message. would it be safe to download the apk from this website?
