is this for me? I dont understand what you are saying at all.
No
Does anyone have an apk for a music mixing software (a lightweight not to sophisticated one for a kosher mp4 player similar to the music editor they have on the q6) that doesn’t have video capabilities?
Have someone that wants to buy a tiq (us version)
  1. How is it better (is it?) then the qin f21
  2. Where can I buy a kosher one (preferably custom app choice, not 100% necessary)
I found it to feel very cheap and like my Qin F21 pro much better
@william I believe he’s a Tiq distributor
You can check out website koshertiqphone.com
What is a standard price for pentesting?
And how is it charged? Per vulnerability found?
I agree to this but the fact that it has epic bands outwins the Qin in my opinion. The f21 bands weren’t working for me.
Dream phone would be f30 with dumbdroid. Having the right bands and my own customization.
Besides the bands you would not say any other benefits the TIQ has over the QIN?
Well I use dumbdroid on the tiq and would use it on the Qin. So software would be the same.
I just flashed triplekoo on my timmkoo q5 and now the touchscreen does not work. Does anyone have a solution?
You dont need touchscreen to reflash, so you can put the original one back on. Or Manufactory, which triplekoo is based off.
Either way, its interesting why the touchscreen isnt working, can you check something for me? Lmk if theres a small line between the vol up and down. Thats how you can check if its a certain older version
It has a small line between the vol up and down.I tried flashing the firmware that is on timmkoos website but it still has the same issue. The touchsceen does not work and when it goes to sleep it wakes up with only black screen.
Timmkoo doesnt have a website. Try using this website’s firmware and following their instructions, specifically the Format All + Download option. https://manufactory.carrd.co/
P.S. I take no responsibility for bricking the device, it worked for me just fine
https://www.innioasis.com/ has same issue with manufactory
You did format all + download?
Dumb question: how do I enable notifications for jtech on Firefox Android?
Settings notifications are set to ask to allow but not getting any prompt or pop-up in jtech
go into your setting → notitifactionand see from there
Did you read my post?
yes
