I dont know what to tell you. Did you try flashing stock again yet?
Have you considered the screen itself may be broken?
Got it working with this rom that timmkoo sent. Wish I could get adb working by modding this rom since triplekoo and manufactory do not work on my device. Wish someone could tell me how or do it for me.
Its interesting, you can actually get to developer options by doing this:
- Plug in the device to a computer.
- Click the notification that says
Charging this device via USB - When you see the menu that has the option to use MTP and all of those, unplug the device.
- You will automatically be taken to the home screen. Now hold the home button to see all apps, click the app that you just got kicked out off, and it changes into dev options.
(Shoutout to @JackNovak for sharing that hack with me)
Thing is, USB Debugging is enabled and it doesnt work. Didnt try it out much.
If you want to use adb, there IS a super complicated way I dont have the strength to type out but I guarantee its not worth the trouble for whatever it is you want to do. I got it to install apps but nothing worked for android 4.4.2 - not Google Play, not 24Six, the only real thing you could get is a browser app, but unfortunately I cant tell you how even if I wanted to.
What is it that you want to do with ADB?
Thanks for the info. I wanted to install some apps via adb. I could not get that working so I added them to that rom and flashed it.
It worked? I once tried modding the rom and it soft bricked. Can I ask what method you used?
Someone I know is trying to get a new phone, not smartphone, but has to have Android Auto, Google maps/Waze, Whatsapp, and preferably chase…
What phones have this?
(Besides for the mega life f1, and probably qin f21)
Thank you!!
I’m biased
but kosher TIQ phone
Thanks, forgot about that… (by the way, you don’t mention Android Auto in your apps list)
Do you know of any other phones that meet the criteria?
Because it comes pre-downloaded
Anyway to make archived messages in Google messages not reappear in my inbox when new messages come in like in WhatsApp?
block the number
Will incoming messages still be received?
recived yes you could look at them if you go under blocked
How do I delete the video player on windows? (And any app that can play videos)
I believe Tag has a program to do that.
firefox’s home page is horrible in my opinion, install this extension and/or set this url as home, thank me later.
What about without tag?
Since what having issues with open metro API not responding? If yes, for his long is this going on?
Open Metro or Open Meteo like weather?
