yeah, it’s only called a bug if it’s bad…
So, good?
All else good?
Double tap to sleep?
yup.
i updated the settings extension UI - Take a look
Ill let you know
Is there the procsimity sensor fix?
Didn’t release a new ROM yet, but users can manually download the APK for now if they want
Chances are your phone has no integrity or possibly basic…
Tricky keybox got revoked. You can keep checking in ksu webui for a new one.
keybox.zip (7.2 KB)
Unzip and use in tricky store
Update your fingerprint while your at it
Labels: [MEETS_BASIC_INTEGRITY, MEETS_DEVICE_INTEGRITY, MEETS_STRONG_INTEGRITY]
Build fingerprint: google/tegu_beta/tegu:16/BP41.250822.010/14082742:user/release-keys
Brand: google
Device: akita
Model: Pixel 8a
TestId: dGVzdGluZy01YjMxN2E3MS01ODRiLTRkYjAtODg1Mi1iMTgyZjA5ZmFhMmE=
What will happen if I don’t flash userdata?
Don’t know, no support.
Will probably make you factory reset on first boot.
So you’re saying it can’t hurt to try because either way I will lose all my data?
I’m saying no support unless flashed the official way ![]()
You can try
OK, thanks.
I was able to flash via TWRP just the super, and also i was able to flash manually via fastboot specific portions
I made my brother the QIN kosher after flashing the new rom here with the speaker fix
But he has a problem with his IMEI and I want to change it, but I can’t change it when it’s with the kosher rom, so I need to return it to a non-kosher state and rewrite the IMEI
I wanted to know what the fastest way is?
It should be noted that Anai can’t enter developer options, and I also have the new QIN
Thank you very much
Just reflash with .bat file and write imei (and bt, wifi)
Then flash kosher super
How do I enter fastboot mode without ADB?
I can’t enter developer options
Autobooter
Or
Press reboot to bootloader
@The-curious do yourself a favor, after writing partitions, pull a backup with mtkclient. Those can be flashed with fastboot.
