Yes
im most sure its good also check what year if its 2024 then its fsure good
Nope, it failed flashing and was opening to Fastboot mode. So I flashed the 1.0.8 but now I have to unlock the bootloader.
Weird never had a issue
Yes you can change the language to Hebrew
The translation is bad. Will replacing the system apps with apps from a Hebrew version help?
Do you need to disable cmndless or have a Verizon imei for Verizon to work properly on this ROM
You must enable CDMA less
How did this ROM fix the MMS issues with Verizon & Google Messages.
- What are the correct ownership and permissions
- If I just paste the APK into /system/app will it stay on factory reset?
When trying to set the keybox Iโm getting an error canโt connect to the Internet.
My data is working but I donโt have the 4G icon in the status bar, thatโs how itโs supposed to be?
(RCS is connected)
Update tricky store and add on
Already did, didnโt help.
Set a keybox yourself. Download one. Itโs been broken for a while.
curl -Ls "https://raw.githubusercontent.com/Yurii0307/yurikey/main/key" | base64 -d > keybox.xml
ืืฉ ืืขื ืฉืืขืื ืืช ืืจืื ืืื ืืขืืจืืช? ืืืฉืื ืจืืฆื?
Which part of the ROM?
ืืคืืืฉ ืขื sp flash tool.
ืื ืืืืืฆืืช
If I reflash, will it wipe userdata
Edit: didnโt mean to ask twice ![]()
