Yes
What do I have to do with the keybox file output?
… getting confused
Monsey or Israel?
Anyone know a reason why wifi calling stopped working?
Can’t add a zelle recipient in Chase! Done it many times before on this phone… How does it suddenly know that I’m rooted?
Keybox has been revoked. Update it.
With what?
No. Have to do it manually.
K so I run that command and get a keybox.xml
What do I do with it?
Go to trickystore and select set custom keybox.
Why dont I just use the yurikey module?
Different than this one?
(I’m on mobile, to complicated to check now myself)
Yeah - different just checked.
BTW - Anyone who wants a one liner command for windows (you can run it from CMD, even though its powershell):
powershell -Command "\[IO.File\]::WriteAllBytes('keybox.xml', \[Convert\]::FromBase64String((Invoke-WebRequest -Uri 'https://raw.githubusercontent.com/Yurii0307/yurikey/main/key' -UseBasicParsing).Content))"
Alternatively you try installing a Base64 exe for windows, like this one Base64 for Windows download | SourceForge.net
there’s also gitBash
Wondering the same thing.
I checked it out when I was in Monsey…
I’m using Release Yurikey Manager v3.0.5 · Yurii0307/yurikey · GitHub together with play integrity fork.
Got rcs working again.
How can I hide Settings → About phone → More Settings from the settings app?
Mount r/w and delete
Delete what
