Small Questions That Don't Deserve Their Own Thread
in my interregation of gemini ai :slight_smile: it claims that some mdm filters can filter play store. so you have a play store that only shows prehosen apps. is this true and can this feature be added to egate.
:ghost: :smiling_face_with_horns: :skull:
I think I finally figured out how to make android auto work, without Google Maps or quicksearchbox… like the F30.
No, no stubs here, that doesn’t work on android 13.
yeahhh…!
Yeah it’s called Managed Google Play
It provisions a work account on the device
how?
anyone know why https://app-builder.madrichim.ovh/ isnt working?
can Managed Google Play be added to egate
I noticed that too. You can try building from the GitHub repo manually. Should work fine.
WhatsApp takes up a ton of room on my phone is there any way to move it to the SD card?
Is there any way to move the storage taken up from my downloads from 24six to my sd card storage? I don’t mean the actual downloads, rather the space that the app takes up would be moved to my sd card. On Kyocera e4810
I had seen the feature on the fire tablet. I think through adb its possible to install on sd card. It could also be on Sai apk installer it has the feature though it may need root.
Do you have a GitHub account?
You can fork the original repo and extract the zip below and build with GitHub actions.
build-apk.zip (486 Bytes)
First time I did this, I’m sure it could be done better. Very cool.
If you want it set up already, just fork mine:
Annnnd - YUP! It works.
They don’t even show up in settings/app/system apps
Isn’t managed Google Play determined by what account is used to log into Google Play?
Correct - you can provision a Managed Google Play account that is just used for the play store but a user can still add a google account for all other features
Care to share how?
As of now, yes, but in a week or 2 - i’ll share…
A post was split to a new topic: Jewish Lyrics Website: Niggun Sheet
To my knowledge, it doesn’t work. When you reach the limit, it tells you to upgrade.
It’s a risk of losing photos and should be taken seriously.
Been using it for years, no issues. 50 something gigabyte uploaded.
if i have an mp4, tha usb debugging is enabled, but when i try to use it on webadb, no confirmation comes up, how to i connect it to adb?
