1: I for some reason whenever I turn on accessibility filter it auto blocks me from seeing my apps list even though that switch is off
2: how do I disable going into sites thru apps, for example there’s a insta, Twitter, tik Tok logo on the bottom of an article that links to that site
3: how do I disable ads
Thanks
For question 2:
In the settings in blue there is an option to block webview in all apps. That should do the job in most apps. For this to work you need the accessibility option to be toggled on.
When I turn it on it just doesn’t let me go into the app at all
Which app? What phone are you using?
Qin f21, TheScore
There is a separate accessibility app for the Qin.
Where do I get?
On the same GitHub page that you got the eGate app on.
This?
If your using the Version 1.26 this is it https://github.com/offlinesoftwaresolutions/eGate/releases/download/1.26/app-external_accessibility-release.apk
So I already downloaded it and it doesn’t work
You need both apps. And in eGate toggle on the option that says “use external accessibility”.
For some reason it installed as a update to e-gate I think
Which version eGate did you have?
1.25 or 1.26
I never used eGate on the Qin so I don’t know how the external app works.
@anon97982153? @samtee-1? @TripleU?
No clue
Ok so I see it in app list in settings, but it doesn’t let me open
Did you turn it on in the main eGate app?
Wdym?
