Changing the imei doesn’t fix this issue at all.
Not sure why it’s working for you on unihertz, (unless your using rcs)
Doesn’t work well with the dpad
This was already discussed here Messaging App to Work With D-pad
It works by me even chats that are not RCS
works for me too
By dialing ##08## it doesn’t do anything by me
Dial * # *# 0 8 # * # *
without spaces.
If you put a “`” in the beginning and end of the code it won’t cut out the star.
And just change it to a Verizon one?
I don’t know if that’s the issue, but give it a shot.
let us know
No it didn’t work ![]()
Do you have any solution?
It just worked for you perfectly right out of the box with Google messages?
Btw, when you pull down the notification shade, which carrier name do you see there?
‘Verizon’
Or
‘Verizon Wireless’ ?
Verizon wireless
There’s a difference between the two?
Oh… Almost there
It must say ‘Verizon’
In that case dial *#*#4636#*#* and click on Phone information, and scroll down until you see a setting called ‘Set Preferred Network’ and select GSM/WCDMA/LTE (PRL) and turn off your phone and back On.
Now go to settings > Network & Internet> Mobile Network > Advanced > Preferred Network type and select LTE/GSM/UMTS
And it’s all done
Yes it worked!!
You’re a freaking legend
Thanks I appreciate it
Regular MMS pictures also working?
does not work on tcl though…
