I’m saying so far I’m just testing it on messaging myself and pictures are working now but for some reason voice notes are sending but I cannot play them maybe cuz I’m sending them to myself so…
Saying you have no problem with voice notes or MMS or anything?
Beforehand in the settings by RCS it did not allow me to connect now it says it’s connected to my SIM card
I also have the voice note issue.
If you want you can save the voice note and listen to it with VLC media player.
( Just clicking Save won’t work, so press and hold the voice note and click Share and click on Files by Google, and it will be saved to Downloads, then go to VLC and look it up and listen to it and if it still doesn’t work rename the file extension to: example.qcelp )
(File extension means the format after the dot/ period)
Oh that stinks
There’s no work around?
What issue are you experiencing on the TCL? All mms or just voice notes and videos (they seem to be 2 separate issues).
In my case, that’s one of the reasons I’m sticking with Message+.
Another way around is, that when I got a voice note I’m switching to another SMS app that could play that format, and afterwards I’m switching back.
Unfortunately I can’t share that app because it belongs to a private company and is made for their phones. (Please don’t ask for it in private, because I won’t share it) But maybe there are public SMS apps that could play that format.
And just you know, that when having an RCS chat with someone you don’t have that issue. Or when someone sends you a long voice note you’ll be able to listen to it even he is not using RCS
For that issue please see this thread TCL Flip 2 Feature Phone - #18 by sb123
Is the quality of the pictures bad, from my experience even if mms works the size is still shrinked to ~30kb~.
What would everyone suggest would be the best message app that wouldn’t have any of these issues?
No it seems good
Message+
And that solves all those issues?
Correct
Message+
doesnt work on tcl
i know but can anyone solve this issue
My message plus by me it does not solve voice notes either? By you it does? I have a version 9.5.5
It doesn’t solve Voice notes you already got.
Just from now on
