Verizon MMS protocol issue (voice note/video not playing)
Sent you Whatsapp
Could you post? (Or send it to me?)
I was working on this after flashing AIV, as I know that all Verizon issues present are there.
Thanks!! This solved the issue.
Say exactly what it solved plz
What have u tested
With the module you posted Image doesn’t get compressed in MMS. I’m on 6.1.3 so I don’t have the VN and thread issues
Nice. I can forget about the phone till the next thing
Wow, thanks!
This solves the compressed MMS issue.
@ars18 u should link it in the 6.1.3 main post
Not 100% sure that it’s related, but after installing the module apps wouldn’t update from the play store. I disabled the module and then it did. Can someone else test?
@walt_cohn ?
Yep, couldn’t update.
So I fixed one thing, and broke another :slight_smile:
Job complete
Now the cdma-less issue, Anyone?
It also made Visual voicemail work, if it makes sense.
Apk’s cannot be installed after this module is flashed.
In addition my magisk which is hidden doesn’t open after this module was flashed
Anyone knows if it’s possible to delete or disable a modeule if magisk is not working to open?
(Through root file explorer etc..)
What’s the error?
/data/adb/modules
All packages fail to parse.
lifesaver thanks.
@ars18 is it possible that you caused play (and maybe other parts too) to actually think the device is a different device and different architecture? (Wouldn’t explain most of the errors though)
Don’t see any issues.
You Da BEST!
