Verizon MMS protocol issue (voice note/video not playing)
Nah
Yep same as before for MMS and fixes the package install problem. :folded_hands:
will it work on the M5? we must make it work!
can i just pull the apk from the zip file and replace it with a root file explorer?
You have this on the m5? If yes, send it.
/product/overlay/framework-res__auto_generated_rro_product.apk
this is from the M5
framework-res__auto_generated_rro_product.apk (108.4 KB)
when done you could sign it so it can install as an update on the M5
gonna test it right now, will be back in a few min with results
Dunno how it will be as an update
why not?
Might not read fresh. Try, if not install the module. If it works, you can replace the apk (ONLY m5, not qin).
on the qin i can’t replace the apk only with the module?
May or may not bootloop :man_shrugging: due to sig
Also depends on ROM
unlocked bootloader doesn’t help in this situation?
Nah
Works?
If after install as update it doesn’t, reboot and try again, possibly only applied once at boot.
I could try
What do I need to do?
try to install the apk just as an update and see if the MMS problem gets fixed
There’s a MMS issue with M5?
Failure [INSTALL_FAILED_INVALID_APK: Scanning Failed.: Package /data/app/~~Gczy63CzrfuNSWMuMmNXHg==/android.auto_generated_rro_product__-OilUEFMd23SHrU3vTmizEQ==/base.apk code is missing]
