Verizon MMS protocol issue (voice note/video not playing)
Yeah, not gonna be on device updateable. Magisk module for testing, if works, keep as module or replace.
will now test the module, need to install root first…
WOW IT"S UNBELIEVABLE
IT WORKS!!!
now if i unroot the phone it falls down and it’s back to the problems
Yeah. You can pull your super, replace the apk with mine, and reflash. No root needed.
do you mean i can replace it just with a file explorer and then pull the super?
No. Chances are you cannot mount r/w, only seen that in one tiq ROM.
Now voice notes on Google messages work?
And does this also solve RCS?
pull the super and replace it outside the phone?
or patch with magisk, and pull the super?
Pull the super, replace apk, flash super.
Or just pull product
basically i need to decompile the super
Or just product. Also:
May i ask you to do it, since I don’t know how to repack the super
Did it fix the voice note issue?
Does it fix the RCS issue?
It fixed the Voice Note and Blurry picture issue.
RCS was already fixed by the company with their latest build on February
build number 20260206M5
I knew they tried to fix the RCS issue what I was told by people that it were still not working properly
Now the biggest bump of this phone is the CDMA less issue.
what’s the big deal?
you turn it On once and you;'re good to go
Pull super and upload
Also a little more complicated (easy though) if you want to keep a locked bl.
firstly it’s still really annoying with US Mobile You have to turn it on every month
