will upload it in a few
When using the right IMEI numbers you don’t have to turn it on every month, as discussed already multiple times on this forum
If you want to have a locked bl with this change send me vbmeta too
Here you go , ask permission, or provide me your email
Access updated.
I replaced it in 6.1.3 and it rebooted fine.
Don’t have a sim in it so I can’t test the MMS.
Thanks. Should be good to go.
I flashed only the the partitions you said and the phone didn’t boot due to boot didn’t match .
So I’m now gonna try to do a full reflash with your rom
Were you rooted before you locked your bl?
If yes, flash my boot too.
flashed the whole rom and it’s NOT fixed
More info
Basically the MMS problem is still the same
U sure you flashed mine? I have to ask
Factory reset?
adb shell su -c "logcat -d -s MmsService" | grep -E "User-Agent|UaProfUrl|Content-Length|userAgent"
replace grep with findstr if on windows
yes I did flash yours.
Now doing a factory reset
Booted on locked bl, correct?
Correct
My bad! Sorry
Patch not in there
how come?
I made a mistake repacking (didn’t sync before unmounting).
One sec
