Let's Talk Tariffs
Let’s talk tariffs for a second :slight_smile:
Please note: I changed the numbers in this document to match $100 per phone just for easy calculations, however the percentages were all kept the same, keeping everything perfectly authentic.
In this case I am buying 4 Qin F21 Pros that are valued at $100 each were purchased.
As you can see in the DHL document at the end of this thread, the following tariffs were charged (of the total amount $400):
  • 25% Default Tariff - Applies to ALL Packages - This was usually avoided on packages under $800, but no longer gets avoided
  • 125% Trump Tariff that took effect in April
  • 20% Additional Tariff (I think its a Trump addon)
So now doing the math on a $400 package, 170% tariff equals $680 in tariffs.
But it doesn’t stop there. They charge sales tax and regulatory charges.
The total comes out to $863.10, more than 215% of the package’s value!
That. Is. Crazy!!!
Pretty sure on smartphones theres no additional tarriff, besides the 25% and a baseline 20% on everything from china
So those 2 tariffs you outlined were identified on this document. Just theres the extra 125%. I think they classify bar phones as non smartphones which is why this was not exempt from the 125%
Technically its any phone with a camera (saw that somewhere else, not in this pic)
So why was this not classified as that?
I dont know then, it should be excluded from the extra 125%
Will DDP bypass the tariffs?
It means that all costs are on the seller, so it should. Just DDP will probably be a lot more expensive.
What a beautiful post. Well written, concise, and enlightening!
The $863 is besides the cost of the phones!? Nuts
I hope your business does okay.
Because they screwed up and should of wrote smart phone not feature phone by the contents details
Nowadays I doubt any seller will do DDP
