recently on November 16 on the lg exalt the email app had an error i know the problem wasn’t just with my phone because i see same problem with my friends as well wh
en pressing the Gmail app there’s a message that says that the app is blocked bc it contains sensitive info
did anyone else have the same issue and does anyone have a solution?
Try to use a different browser to login
how do i use a different browser on a lg exalt? that message comes up when i click on the email app
im able to login to email on the regular internet but not on the email app
Same here. Any solutions?
If you could somehow clear the data of the app or sign out through settings > Phone settings > Acoounts > Email and then remove your accounts and try the method found here. I personally used that method for the LG Exalt and it’s still working.
P.S. I do remember hearing that google will stop allowing you to use 3rd party apps to access your account. Check out this article.
I figured out a way to get gmail back up and running on my lg exalt. It randomly stopped working about a month ago. Now it works perfectly fine.
1.Enable 2-Step Verification: Log in to your Google Account and enable 2-Step Verification if it’s not already set up.
Access App Passwords: Go to Manage Your Google Account. In the search bar at the top, type “App Passwords” and select the option.
Generate an App Password: Follow the instructions to create an app password. Google will generate a unique code for you.
Sign in on Your LG Exalt: On your LG Exalt, enter your email address as the username. Use the app password (the code Google provided) as the password.
This will allow you to successfully log in to your Google Account on your LG Exalt.
why doesnt it work for me?
yes
did you put in the password that got generated by google? Do not enter your own password on your flip phone. just use that one only.
Also, Make sure it is entered exactly as shown. its case sensitive. make sure all spaces are there. to do that you will have to enter the password on a text or notes etc. and copy paste it in the email app. otherwise you won’t be able to add a space when entering the password.
then we must have diffrent screen on the exalt bc this what i have and i use space key
You must press other which is option 6. Then add the app password before entering your email in. It shouldn’t open your browser at all.
Check out this clear guide.
If your using a lg device don’t forget to follow step 8.
it still went to the browser if when i put 16 digit password in first and then i put email and it brought me to browser???
its a gmail account
i dont see an option “other” once click on app passord theres just a button to create
anything i do it jumps to the browser
i put in only the password generated by google but what ever i do it jumps to the browser which causes the same issue
when your on this screen it doesnt jump by you?
I don’t remember trying it with my browser open. Try it with your browser blocked.
