Probably another vibe coder disconnected from reality.
What was your conclusion, did you reset?
No.
Still hope to find a way to get my data off..
Been planning on popping into a few phone shops to see if they can do anything
Do you know if it is possible to decrypt userdata from recovery using twrp?? Was just curious for a project I’m working on…
Yes, it is possible. But the TWRP build must be built with support for decryption for the specific vendor (qcom/mtk)
If you have a screen lock password, that can also complicate things
Got it. Best of luck. If you discover a breakthrough, please let us know.
Is there a way to just command via terminal to block Video capabilities? or do I have to put on a new modified gallery apk?
You need to install a new APK, and uninstall the original one
Anyone know the cheapest basic phone (not necessarily kosher) that can work with any carrier?
is this the regular tcl gallery?
Sorry, I didn’t know you were talking about TCL
The above application is not compatible with TCL
To block video try adb shell su -c pm disable com.android.gallery3d /.movieactivity
Note: if you do this a factory reset will reenable the video playback
to reverse adb shell su -c pm enable com.android.gallery3d /.movieactivity
where is the @TripleU mdm installer?
Had a old HP probook in my house. I decided one day to fix it up, Battery refused to charge though PC worked on ac, tried replacing battery, motherboard and ac adapter, still didn’t charge. Does anybody have any ideas before I return ssd and ram I bought for it?
Can someone tell me where the “Where can I find that?” thread is?
Can someone tell me why, when I post in this category, it doesn’t go to the top and it doesn’t show as if it’s a new post on this topic?
Issue happens with some threads, likely because of Whispers.
Super annoying.
What’s needed for tap to pay to work? Is it just an integrity level (which would mean it can work with root with the correct modules)?
