Ro2rw issues
When you do ro2 RW it saves in user a backup of the super and then you’re supposed to flash the super so I did that and now I’m having issues deleting the backup it’s about 5 GB of files and using up most of my space if anyone has a fix please let me know
@TripleU @FliphoneBochur
Thanks
factory reset
And ro2rw will stay?
yes
Any other alternative? It will be very hard for me to reinstall all my apps and restore all my data…
The RO2RW new depleted super is somewhere in data/local/tmp.
the exact path is said in the script when it says “the script is now paused”.
delete it. It’s a decompiled super…
Nah before I ask the question I tried chatgpt and it just wasn’t working I finally got it… Through termux…
Here’s what chatgpt told me we did during the process I do not know what it means but just in case you’re curious
Absolutely! Based on everything we’ve seen, the main issue was a corrupted folder entry in Fuse-managed storage that refused to be deleted due to broken metadata. The "Math result not representable" error usually happens when the filesystem can’t properly reference or calculate the size/location of a file, often due to corruption or incorrect attribute handling.
Key Problems You Faced:
  1. Fuse restrictions/storage/emulated/0/ is managed by Fuse, making direct deletion harder.
  2. Root ownership conflicts – The folder was owned by root:media_rw, preventing normal access.
  3. SELinux enforcement – Likely blocked some of your deletion attempts until switched to permissive mode.
  4. Filesystem corruption – The "Math result not representable" error signals corrupted file metadata.
  5. Persistent shell lock – The shell process (sh) was stuck inside the folder, preventing deletion.
  6. Unlinked but undead files – Files were removed but still referenced due to Fuse caching.
How We Fixed It:
  • Exited the directory and killed locking processes (sh was holding onto it).
  • Tried direct deletion via /mnt/pass_through/0/emulated/.
  • Used find to remove files first, then wiped the empty folder.
  • Forced media refresh (am broadcast …) to clear cached references.
  • Attempted low-level removal (unlink and dd to zero-out files).
  • Recovery mode (e2fsck) helped clean up residual corruption.
