eGate-Android MDM_Continued
Which phone?
Samsung tablet active 5
What screen are you stuck on?
The login screen
I entered already the license code and password
And can’t login
Is it a password error? Can you get a screen recording that shows the problem? “I can’t log in” is too vague for me to troubleshoot.
I enter the license key and Set the password.
Then it get me to the login screen
I entered a password that I set.
It opens the app and it jumps back to the longest screen.
So the password is good cause it opens the app but Somehow, it crashed.
Are you using the latest download available?
When is the next update coming?
Yes
Any help
It would seem that it is encountering a bug. Is there any way you would be able to get the adb logcat output of the crash?
Not for a bit yet, unless there is a bug fix that needs to be done.
What’s the option attempt to block videos?
And what’s the option disable app view in settings?
The option to block video blocks some video players.
The app view in settings is supposed to block the list of apps in the settings window, but I don’t think it works currently.
When setting the dns and accessibility on its still not disabling changing the private dns
Thanks for the report. I will investigate.
Use the file manager to install the apk file.
anyone else having problems checking out on the website???
Everything seems to be working on my end? What part of the process is not working? Can you PM me a screenshot?
i emailed you
