eGate WhatsApp Block Not Working
Any help?
Egate installed, device admin set.
Whatsapp restrictions all set to block.
Everything still works.
Did I forget to set something up?
Did you switch on the accessibility option?
See this post
yes
From my experience the Block whatsapp AI option just causes the app to crash.
I see. Any WhasApp version where it’s known to work?
Try to toggle the accessibility switch off and back on.
no difference
Everything else about the app works?
You may want to block the activities instead.
Haven’t tested yet
yeahhhh I guess, I was looking more for a solution that just works as I’m doing this for a friend
actually, none of the egate blocks are working
edit: Play store block is
What phone are you using?
f21 Pro
Never used eGate on there, try @DonBot.
That is right. I can’t achieve a consistent block, so will probably remove the functionality at some point.
Do you have a way to block activities?
Alright. Whats with the extra accessibility apk for f21 pro? Can’t seem to activate it.
Did you make it into an mdm?
