Message Plus Discontinued
I’ve seen online that message plus has been shut down. Will that in any way affect LG Exalt or any flip phones that use message plus?
If not then what exactly was discontinued about the app?
Message plus server is going down. So all groups, profiles etc. are not gonna work.
The app may continue to function as a offline messaging app…
  • Think: :thinking:
    You don’t need data to send a SMS message…
If your basing off the fact that you don’t need data does that mean that MMS which usually does need data won’t work anymore?
it depends on carriers, but these days, mms and data are separate.
:+1:
Anyone knows how to get rid of the update needed banner?
(the app still sends and receives messages just the banner block the main page)
Is this a flip phone?
No
Try app cloner
I don’t think that’s correct
Right the app might work but you cant get rid of that pop up i tried multiple versions
So that popup will go away if mobile data is disabled from the app, I tried this with a VPN that disabled the mobile data from only this app, MMS still worked, if someone knows how to properly modify/clone the app to disable mobile data/wifi that would make message plus usable.
send the apk here
Thanks for trying to modify it, however this one crashes instantly
I tried it 3 times didn’t work probably something verizon puts in to block it
Does anyone know if this works well on tcl?
Just noticed that all remaining Message+ groups that was still working under a 588 - area code - phone number, stopped working.
And from now on it looks that it will just be history…:sob:
Who remebers the admin “TripleU” from the WORLD and ABISEL groups? i had 2K plus members with all groups combined… aaahh… those were the days…
